Typhon Motor assembly question
palmryde
  1. BigRock 4x4
  2. Granite
  3. Typhon 6s
Hello All, This weekend went to replace the bearings om 6s stock typhon motor. Puled the end caps off, set the motor on the bench and went inside for dinner. When i came out the motor had rolled off onto the floor. I am not sure if I found all the pieces/spacers and spring washers. I have 2 spring washers and a alum spacer about 1/4 inch long. What else am I missing? And does someone have a pic of an intact rotor so I can see how it all goes back together?
That should be all there was.. 2 spring washers, 1 spacer..
Washer against rotor.. u side up, spacer, then spring washer #2 u side down towards spacer.. I've seen them assembled many different ways.. but this is how I typically set them back up...👍
Great thank you
