STLMaybe this can help?
https://www.ebay.com/itm/3344027959...q7FPNHENTvG&var=&widget_ver=artemis&media=SMS
I know it's not the STL file but an idea of what's out there. Hope it helps at least.
I've been seeing those pop up everywhere. I'm curious as to whether they actually work or is it just another gimmick?Maybe this can help?
STL
https://www.thingiverse.com/thing:4982263
I have one of the 6s printed motor supports on my Notorious from that link above, that sellers store. It works ok. It fits really snug & doesn't move. It has a hole to screw it down but I didn't do that, mine just is snapped under the motor & looks cool & it's functionalI've been seeing those pop up everywhere. I'm curious as to whether they actually work or is it just another gimmick?
They help prevent the motor mount from bendingI've been seeing those pop up everywhere. I'm curious as to whether they actually work or is it just another gimmick?
And that's an old photo. I took the scoops off & have reg shroudsThe scoops are worthless though. Just cool looking. Just pulls dirt all in the fans. Support does its job
Yeah I get that part. However, I've learned that for every part strengthened, you create a weak spot somewhere. Personally I use foam/rubber shelf padding tucked under my motors.and get a 50/50 between it bending and flexing. Then again I'm not a "jumper" with my RCs so I can see a benefit in totally eliminating flex for those hard landings.They help prevent the motor mount from bending
Use some fine meshed stainless steel screenings. Not window mesh, this one came from an eavestrough cover:The scoops are worthless though. Just cool looking. Just pulls dirt all in the fans. Support does its job
That looks awesome! Ive thought of using K&N pre-filter there. I have one left over from a car filter.Yeah I get that part. However, I've learned that for every part strengthened, you create a weak spot somewhere. Personally I use foam/rubber shelf padding tucked under my motors.and get a 50/50 between it bending and flexing. Then again I'm not a "jumper" with my RCs so I can see a benefit in totally eliminating flex for those hard landings.
Thanks found the file now just someone to print it for me appreciateMaybe this can help?
STL
@Tex KoderThanks found the file now just someone to print it for me appreciate
Welcome!Looking for a 3D file to get a 3d printed engine support for my 3s big rock if anyone has one could be appreciated or point me in the direction
PM me if you still need help with thisThanks found the file now just someone to print it for me appreciate
I could love to get the help from one of you guys but I'm assuming most of ya are in the states I'm locates in Canada hhehe
Whereabouts? Locally we have one of these and I know guys who have used them with no complaints.I could love to get the help from one of you guys but I'm assuming most of ya are in the states I'm locates in Canada hhehe
I did find someone in Facebook market to do the small part and not a bad deal 2 supports for 30Whereabouts? Locally we have one of these and I know guys who have used them with no complaints.
https://www.i3dstore.ca/
Also,hit up FB Market. There are always ads for 3d printing but how good they are is anyone's guess.
