I was looking into fixing the wheel wobble of my Typhon 3S, found some videos on YouTube, but that did not give me any satisfying results.
Started to look into the problem and possible fixes myself.
On my Typhon there is space between the outer bearing and the wheel hex, is about 0.2mm, using a feelergauge to check that.
If you would find 6x8 washer with a thickness range of 0.1 to 0.3mm I would have a perfect fix for the wheel wobble and what I found was the Mugen B0766 shim set. 6x8mm in thicknesses of 0.1, 0.2 and 0.3mm, 10 of each thickness. Happy days.
I started with a 0.3mm shim between the bearing and the wheel hex and I could slide the pin back in with ease. Added a 0.1mm washer and I had to force to pin in.
0.3mm it is.
Went around the car, 2x 0.2mm and 2x 0.3mm did the trick and the wheel wobble was minimalized and the bearings run smoothly.
Again, happy days.
0.3 shim in place
Hope this helps other to get rid of the wheel wobble.
Maybe worth a sticky?
0.3mm it is.
Again, happy days.
0.3 shim in place
