Typhon My stock camber differs from the manual
Yonic
Tel Aviv, Israel
  2. Senton 3s
  3. Talion
  4. Typhon 6s
  5. Typhon 3s
  6. Voltage
Hello,
Just noticed that the front camber setting on my Typhon doesn't match the exploded view, and i wanted to ask how your Typhon came stock.
The exploded view specifies two clips on the top arm, but none on the lower.
My Typhon setting from the factory is one clip on the lower arm, and none on the top.
Is mine an error? how did yours came?
I can't answer how many or how thick where, out of the box but I would not count on that as being correct. Production tollerences and care during assembly doesn't appear to be stellar on any RTR. What matters is the result. Typically you should be in the 2-3 degree negative range, but what you ultimately need depends on the surface, tires and driving style. There is no correct standard setting, per se.
Hello,
I got my Typhon v3 a couple of weeks ago.
Like yours, no spacer on top. One on the bottom at each side.
