Nero ESC Programming Question
craig72
  1. Kraton EXB
  2. Nero
  3. Talion
  4. Typhon 6s
Hey gang,
I have a question about the programming of the BLX200 in my Nero. I have several opposing sources and cannot determine the variable and options available.
In the book that came with my model, with ARB10258_4 on the back cover, I have the following (default bold):
Variable: Setting 1 2 3 4 5
ESC Thermal Protection: 105C 125C
Motor Rotation: Normal Reverse
BEC Voltage: 6.0V 7.2V
Brake Strength: Low Mid High
Punch Setting: 1 2 3 4 5
In the online manual with ARB10258_5 on the back cover, it states the following (default bold):
BEC Voltage: 6.0V
The problem is, my ESC does not match either of these. I have two options available for Variable 1 (ESC Temp), but I only have 1 option available for Variable 3 (BEC Voltage). So my version does not line up with either of these two tables.
Anyone have any thoughts or guidance on this?
Thanks!
You only get 5 options.
Yes, I have 5 options, but since my options don't align with either of the manuals, I cannot be sure of what exactly I am changing.
