Nero rod ends keep breaking
Ole Fart51
Louisiana
  2. Talion
loving my Nero except for the rod ends break every time I run it. Can anyone suggest a better replacement than stock? Arrma, please fix this!!!! Getting a lil embarrassing.
If you're breaking that often you may want to try changing the suspension settings a bit to see if it helps. I pulled one out one time. Since I replaced it I've never had an issue. I think if the factory settings aren't suited to your driving style or the area you drive all the time, you're going to break the same part a lot. Change the settings and see if you can reduce breakage.
