Nero steering servo
Josh nortz
Farmington NY
Ok i have a problem and can't figure out whats up. My Nero will turn one way and then stay. It will not turn back. I took it out and same thing so gears inside all fine... bad motor??? Or bad receiver I don't have another servo to test it on unless I take it out of Kraton... advice??? New servo?
@WoodiE... I actuly took the servo and plugged it in to my kraton reciver and got same result. Turn one way and stay there... also does not center when turned on... so iam gonna contact arrma when i get a minute... probably just upgrade to better servo on both trucks.
I just changed mine in my Nero I wasn't having any trouble with it but I seen others were so I changed it before it became a problem I installed a Fitaba S9177SV. It has 511 torque and speed is .12. I like it a lot.
Just finished installing savox sa-1231sa with 444oz-in .14 @6v... i had to adjust bec cout ov servo to 6v but it wirks awesome... it is a tad taller i believe i did not check dimensions but i had to trim unused wire routing tab off and it was a breeze.
