I bent some EXB ones from bad landings. I also ordered the M2C shock kits but they didn't show up todayMy standard EXB shocks have been fine on my Kraton, but on my RTR Outcast I did bend 3 of the 4 shock shafts and switched to the 7mm kit from M2C and they are MONSTERS! Great looking build with some top notch parts so far.
Thanks for cluing me in on the Vitavon steering setup. I was not happy with the factory steering servo setup. I think this one is much better. I ordered one today.Here's my Vitavon steering thread..fwiw
https://www.arrmaforum.com/threads/vitavon-steering-system-install-on-k8-exb.62568/
No worries made a huge difference!Thanks for cluing me in on the Vitavon steering setup. I was not happy with the factory steering servo setup. I think this one is much better. I ordered one today.
..I'm doing the same thing except I got the wrong kit. I got the blx instead of exb so the shock rod ends are wrong. Got all the way to the end of the upgrade before I realized the ends won't fit in the exb spring basket/thingy. I've already emailed them and asked if I could exchange ends and cover the differenceI received my M2C parts today. Started rebuilding my shocks with the new 7mm shafts. You have to use your existing pistons for the shocks with lock nuts.
Bummer, hopefully they take care of ya...I'm doing the same thing except I got the wrong kit. I got the blx instead of exb so the shock rod ends are wrong. Got all the way to the end of the upgrade before I realized the ends won't fit in the exb spring basket/thingy. I've already emailed them and asked if I could exchange ends and cover the difference
My batteries are too long so I am going to have to cut one end of the battery trays for the cables...I'm doing the same thing except I got the wrong kit. I got the blx instead of exb so the shock rod ends are wrong. Got all the way to the end of the upgrade before I realized the ends won't fit in the exb spring basket/thingy. I've already emailed them and asked if I could exchange ends and cover the difference
Did you them adjust them all the way out? You can take a couple screws out and reposition the back half to get a little extra.My batteries are too long so I am going to have to cut one end of the battery trays for the cables.
We'll see. It was my fault..Bummer, hopefully they take care of ya.
I’ve had mixed results with them. One time they told me to basically kick rocks and other times they sent me what I asked for.
I designed trays that provide an extra 10mm of clearance. They use up some of the dead space in front of the trays.They are adjusted all the way back. To get enough clearance they hit the rear suspension arms. 9500 mAh, 90c continuous with 180c burst. CNHL brand.
Totally forgot about these..I designed trays that provide an extra 10mm of clearance. They use up some of the dead space in front of the trays.
Message me if you need some.
