Blue loctite is perfect but remember to let it cure for 24 hours. I think that is the thing with RC trucks especially the more powerful ones, you never know what will go wrong but I find I have more fun tinkering than driving sometimes. Loctite the pinion and the slipper clutch and things shouldnt come loose again.stupid question, do you put threadlock on the grub screw or actually on that metal sticking out of the motor or both?
Blue TL comes off with a bit of careful turning, its usually red or orange that may require a bit of heat to loosenWhen it comes to the time to change the pinion for whatever reason, how do you guys remove the TL?
I never buy Lipos from hobby stores as its always cheaper online by quite a far margin, even the skyrc d100 is cheaper off aliexpress. RPM A arms, fast freddy or Jims bearings, I bought HR pivot balls, a whole set of spare parts from Jennys, a flysky GT5 transmitter, HR shock bodies. Cant think of anything else. Did no one tell you RC trucks is a endless money pit.Right a little update, what do I do when someone sold me a lemon? I give them even more money!
I walked into the shop with everything I bought and the guy took the car inside, put some TL on the grub screw and let it rip inside the place! I thought hang on aren't we supposed to wait 24 hours?! I asked him for a long term solution and he just said it's a fast car, it will come off again and it's not under warranty. Not very reassuring.
Anyway I bought another stick of 4s Lipo, exchanged a better charger (SkyRC D100), bought some tools, so far £600 spent, let's see how long this hobby will last. Anything else I need?
Lol. I haven't broken any of the ones that hold the hexs but every time i open a diff on my k6s there is at least one broken.Those pins break. Fact.
Opposite for me.Lol. I haven't broken any of the ones that hold the hexs but every time i open a diff on my k6s there is at least one broken.
I would use a silicone based spray over standard WD40. Some say it’s bad for rubber, so consider that when spraying tires. I still use it on mine, but figured it was best to pass along the note of caution.You guys have been a massive help thank you, if you don't mind I will keep asking through this thread instead of opening new ones.
I just ordered some more of those metal pins, a couple of nuts as spare, a 8mm nut driver (free plastic ones are destroyed already), a toolbox, medium strength threadlock, anything else you guys can think of that's MUST HAVE when you take it out for a bash?
After a run, if it's not too dirty I tend to just leave it on the stand. But if possible I'd like to spray it with something to keep it lubricated, I can see there's mixed feelings about WD40, how about GT85 or any other suggestions?
PUT THREADLOCK ON EVERY METAL TO METAL CONNECTION. If you don't enjoy taking it apart and putting it back together you're gonna have a bad time. The more you do it the easier it gets.
Also, I don’t know if you’ve purchased a-arms yet or not, but the RPM arms are the ones you want to buy. The stock ones never last long.
If you lose another pin or nut, then consider the Hot Racing hexes next time. They use a standard 17mm nut instead of that dumb little 8mm flange nut.
Yep that’s the silicone stuff. ????Got it thank you for the advice.
I do enjoy working on it, I actually liked taking that pinion out like i've achieved something
I just hoped my new car wouldn't develop issues so soon
I've had a look, this WD40 variation any better?
No, no spare arms yet but I will get the ones you mentioned thank you.
Ahhh...I wish you told me earlier about the 17mm nut because I just ordered the 8mm nut driver to work on it Think I'll stick some threadlock on it for the time being...
