- WIS.
- 4x4-Mega
- Kraton 8S
- Kraton 6s
- Senton 6s
- Senton 3s
So got rpm a-arms and i see no place for droop screws. Isnt that going to be hell on the drive shafts
Thanks that worked out grate on the 10mm shaftsNot really on the CVD's (still a decent angle fully extended) but the shock rod ends and the pistons, yes. We used to put Nitro fuel tube inside the shocks on the shaft under the piston as a cushion and to limit the down travel. You could also use spacers but I'd still recommend some type of absorption/dampener like fuel tube under them if you choose that route.
