Manley00
- Granite
- Kraton 6s
Just built a Notorious. Drove the first day everything ran fine. 2nd day the car is making a binding noise. First thought was diffs.
Removed front diff and ran- noise stopped. Replaced that diff with another functioning and noise still persisted.
Replaced center diff with functioning center diff from another. Noise still persists.
When low speed there is no noise- under throttle there is what can only be described as a cracking noise/ think baseball card in tire spokes but a higher pitch.
I feel like something has loosened somewhere. It can’t be internally in the diffs because they have all been swapped from a working Kraton. Like I said- when removing the front differential the car did not make the noise any longer.
Any thoughts? Anything someone has ran into before?
