Just curious, I don't see much about the Notorious. What are your thoughts on this model?
I have it and think it is an awesome machine.
Thanks for the info.It's the same as the Outcast but with a different body. Search for that and you'll find more information.
I have three Notorious/Outcast 6s. They are my favorite. Most people just consider them a stunt truck but with careful tuning you can make them do just about anything. By varying the tires, differential oils, pinions, and changing the settings on the ESC you can make them backflipping wheelie machines or tame them to just rip around at full tilt. Straight out of the box they are set up for uncontrollable fun and not speed.Just curious, I don't see much about the Notorious. What are your thoughts on this model?
Yes or Kraton parts tooSo do any of the EXB parts from the Outcast directly swap over to the Notorious V5?
Yes all very similar. The rear chassis brace is same as a Typhon. Noto is the SWB typhon chassis w/ Kraton gear / A arms, bigger tires.So do any of the EXB parts from the Outcast directly swap over to the Notorious V5?
