You can actually charge any lipo off of any lipo rated charger. Just buy adapters accordingly.can you charge the notorious battery off a traxxas charger? sorry i didn't see a section for the notorious so i put it here i think it needs a adapter but other than that i don't see why not
Never owned any Traxass stuff, but do they have a balance port on their chargers? Wondering if “smart” chargers use the balance plugs or if they use the smart plug?You can actually charge any lipo off of any lipo rated charger. Just buy adapters accordingly.
Yup they have balance ports. Here I’ll show you because it’s hidden. There’s usually a little blue cover over it.Never owned any Traxass stuff, but do they have a balance port on their chargers? Wondering if “smart” chargers use the balance plugs or if they use the smart plug?
I think I’ve seen them with a cover then. Makes sense now. ??Yup they have balance ports. Here I’ll show you because it’s hidden. There’s usually a little blue cover over it.
I only use the one above (first gen smart charger) to balance anymore, just because it is very good at balancing packs quickly. The one below is my main charger for any battery I own.View attachment 100910
The only inconvenience is buying an adapter but I just use alligator clips crimped to a traxxas connector pigtail and it works fine.I think I’ve seen them with a cover then. Makes sense now. ??
