Do you happen to have the link for the shocks... Also has anyone had luck with a better diff. I put 3s setup in mine and vaporized the plastic out drive cups on the diffsBought two groms about a week ago, decided to pick up a third a one a few days later.
I started off by designing an esc mount for the servo. This is slightly larger than the one available to purchase from arrma. Does it’s job well only took me a few hours including print time and a few revisions.
After that was the power plant, I love castle stuff but wasn’t patient enough to send the micro x2 back to CC to have it swapped out for one with a built in BEC. This chassis is too small for that much wiring. This is a 390 sized sensored brushless motor. 4500kv.
View attachment 336294View attachment 336295
Now I did want to run this sensored so I had to make a small notch in the chassis. I wish the battery tabs would have been lined up towards the top but because of the hole spacing on the can this is the only way they would fit.
View attachment 336296View attachment 336297
Up next is ESC. I had a spare Hobbywing just stock laying around. It s a 1/10th scale 60a ESC. So I did some measuring and it’s roughly the same foot print to the Micro X2 so I decided to go with it.
View attachment 336300View attachment 336301View attachment 336302
Up next, shocks. Too impatient to wait for arrma shocks, saw that someone posted a link for these on amazon. 20$!! Plus everything is interchangeable, and by everything I mean, springs, spring retainers etc. They’re almost identical. Stock springs are a little long so I stuck with what was on them because I wanted the truck to sit a little lower.
View attachment 336305View attachment 336306
Up last is just finding exactly how I wanted to route everything, found a way I was happy with. Here it is compared to stock form. Overall it weighs about 50grams more than stock. Not too bad. I do have an NDSRC micro servo on the way but that hasn’t shown up yet. These stock servos aren’t bad it’s just a ton of slop in the steering assembly.I bet there will be a mini typhon released at some point, that’s what I’ll save the servo for.
Here’s the final setup I decided to go with after getting the sensor wire routed.
View attachment 336313View attachment 336315View attachment 336314
