Stock is F10k/C100k/R10k but those are really light for most people’s tastes. Most go F100k/C500k/R50k or somewhere in those ranges.I am having to replace the Diff Outdrive- what is the suggest weight in the Diff since i will have out, and what lube do you suggest on the gears when reputting back together, anything available at Home Depot, Amazon?
Ok newbie here, I have the red n tacky for the outside.... when I unscrew the diff to change that piece what fluid is best and where do I order from? Don’t quite understand all the numbers....red-n-tacky on ring/pinions
100/500/100 f/c/r inside the diffs
white lightning clean ride chain lube on outdrive cups/bones/cvd joints
You can get it on amazon, team associated is one of the preferred brands.Ok newbie here, I have the red n tacky for the outside.... when I unscrew the diff to change that piece what fluid is best and where do I order from? Don’t quite understand all the numbers....
