My spur gear and pinion are bothering failing I just upgraded to a hobby wing mad 10 combo and every ring I strip a spur gear and the pinion comes lose on the motor thing and I cant get the pinion to stay what should I do please help
Wait I belive it's a 3x3 unless the 17t is a 5x5 because maybe the 14t needs a 3x3Should be 5x5mm They come in pack of 10 for like $2.99 You can buy them everywhere, hobby shop, Horizon, Ebay, Amain. Hit up your cookie jar.
Get yourself a good set of tools like @SrC said above , they're cheap insurance, that's why you're having these issues!
It's notYou could use a t driver, but you need good quality tips, no monkey metal or you will keep stripping your grubs.
So is it a 5x5Wait I belive it's a 3x3 unless the 17t is a 5x5 because maybe the 14t needs a 3x3
It's not
It can also come in 5x5Pinion can come with 2.5, 3.0 and 4.mm setscews if that is what you are referring to. Pinion size is not always the determining factor. It' by brand. MIP geras and Tekin pinions for instance just choose to use larger setscrews for example.
Hope I understood the above correctly enough?
So what should I buyYes, it's possible, usually based on Pitch size or Modulus of the gear. Larger Motor shafts get larger set screws in general. FWIW.
Ok I have a arrma granite 4x4 mega upgraded to hobby wing max 10 and I need to find the grub screw for the 17t pinion cause I upgraded to a 17t pinion and the grub ist strippedYou never stated what exact Arrma rig you have. There are so many. Did you know that? AF covers all if them. Should have posted this in the specific model thread listing.
Go to arrma-rc.com and look up you your vehicle diagram, the parts and description of size and #'s are shown. Everything is there. It's your bible. That's how we all do it.
Good Idea I'll tryWhat brand was the upgrade pinion? Arrma? Or generic?
If you were able to remove the set screw ,and you will need to do this anyway if wanting to install another one, try installing standard screws into the pinion to establish what size it is. 2, 2.5 3.0 ,4mm and so on. At most, the setscrew needs to be only as long as the original or the depth of the Pinion threads. Too long is no good obviously.
This is what I got from Arrm-rc.com for the mega 4x4. For the stock 14T pinion. (48 pitch Teeth) Do you still have the old stock pinion and setscrew for reference? Maybe that setscrew will work? stock is 3mmx3mm
SET SCREW M3x3mm (10pcs) (AR724303) | ARRMA - Designed Fast, Designed Tough (arrma-rc.com)
I think it worked better cause it was smallerGood Idea I'll try
