Gdub34
No pics but I ran a full pack 6s 5000ma 50c through my typhon today. How do you guys get all the grass and muck out of your rigs or do you? Mine had about 1/4 pound of mowed grass under the body upon post run inspection. I turned her over and shook her out after I took the battery out and there’s still a good amount of stubborn grass in there? Also, the Exb bumper saved my arse a couple times today when I hit trees going maybe 25 mph. Not a scratch on her and you could watch the spring action of it at work. I was able to check the motor temperature right after I hit lvc? It showed 172 on the end can but felt much hotter to the touch to me fwiw. The ambient temperature here today was around 78 and bright sun if that matters. She ran perfectly today and I’m super pleased with the Exb super basher front bumper. Are those good motor temp considering the weather or should it be running cooler? Btw, the battery was just slightly warm upon removal and the esc was barely warm as well. thanks
