Yes, and balancing is critical with any RC wheel/tire or the bead will most certainly separate on 6S rpm power . First thing that should be done out of the package, grab a team associated tool or make your own hub table mount.The one thing I remember when I had those wheels is the bead would come unglued fairly easy. I think the low profile of the tire had something to do with it. Maybe venting them would help.
The trencher LP is slightly shorter and slightly wider. Was planning to get those aluminum zero offset 17mm hex adapters for the mojave. Will venting the tires minimise the ballooning?Use them on most of my truggies/SCT as one of the most dynamic wheel/tires available. I’d plan on having aluminum or spare 3/4 hex adapters if you’re really sending it.
That was what im planning to do with my mojave exb and kraton exb. Another option are the
1/8 Trencher LP F/R 3.8" MT Tires Mounted 17mm Blk Raid (2) PRO1017510.
