Say they crash with wheels fully turned, it could burn out a servo quicker. Are you running on loose or solid surfaces mostly?
@Ari33 pretty much. I’ve see a servo go out when an inexperienced younger driver ran it into some bushes. The wheels were fully turned and the stability control was trying to force it back to center.
I have Power HD servos in both, so in case of stall, the servo will substantially drop its power consumption after a second or so. I have also retained the stock servo savers. I find when the radio is off that I can turn the wheels almost to the end stops before the servo moves, so I doubt I would ever be able to get to a true stall with the stock saver.
