Limitless Quick question about limitless
Jester194
Connecticut
  1. Talion EXB
  2. Typhon 6s
If I get a v2 limitless can I put all the electronics from my talion or Typhon in it until I get money for stuff
Ok cool... My other problem is ground clearance, I live in New England so smooth roads are hard to find... Do it need glass like roads to run
I’m in Massachusetts, you don’t need glass, unless you plan to go 150+mph right off. But look around and you should be able to find something around CT, what part of CT are you around? I’m in the central MA area near the MA/CT border of rt 84
Belrin area, pretty much central ct
Would I be better off with a arrma felony
If you're finding it difficult to find spots to run the limitless, it may be best to stick with your Talion and Typhon. I'm in the same situation as you, only found small parking lots or neighborhood straights to run my limitless. Ended up selling it. I find my Talion XL build with powerhobby scorpion belted tires checks many more boxes.
