- Felony
- Fireteam
- Infraction
- Limitless
- Kraton 8S
- Kraton EXB
- Kraton 4s
- Mojave EXB
- Notorious
- Outcast 8s
- Outcast EXB
- Talion EXB
- Typhon 3s
- Typhon 6s
- Typhon TLR
man my liperior suck balls if I set lvc to 3.7. iirc I had to set them to 3.55 before they became decent. I was getting bad voltage sag which was leading to my electronics acting starved for power. Lowering the LVC turned them into decent lipo for me and I haven't had any problems with them, IR still seems about the same. For some reason I remember rcbattery.com recommending 3.4v or something but I could be confusing them with a different brand. I also have to lower lvc for my cnhl racing packs too. My smc,'s get set to 3.7 though.Based on the 3.6V, you simply ran them into the ground. High C batteries don't like it. At the end of run, your lipo should be in the 3.7V range to keep it healthy. That is my guess.
45VC is considered high for them, they don't inflate the C ratings like all others.
If you keep running to LVC, this is what you will get.
Cheaper '100C' types are in a realistic 15C range, and they can take the low voltage a little better, they just get there a lot quicker.
https://www.smc-racing.com/index.php?route=product/category&path=174_173
Some cool info on higher IR lipo needing a lower lvc setting, for anyone interested!
