Thank you granite fox will checkCould be a number of things. Busted teeth on the spur gear or blown rear diff. Easy to pull the power module and check. Also check to see if your motor mount plate is bent. Once you have the power module off rotate the rear diff and check for any binding or grinding. Good to keep a spare diff and a spare spur gear in your spares. Fairly inexpensive.
I’ve seen those listed and was also curious. Cheapest option is probably to either get the whole diff off a 4s outcast/kraton on Jenny’s (inputs are sold separately as a pair) - about $85 total for both diffs, or get the inputs off Jenny’s and just the metal crown gears from amain hobbies.Thanks again guys for advice. It was the input gear. Has anyone tried a metal crown and metal input gear as below ?
I already have a metal slipper in my power module so any future impacts would go directly to motor / ESC I spose ?
https://www.ebay.co.uk/itm/36410793...ar=633469292695&widget_ver=artemis&media=COPY
Thanks again
Simon
