- Mechanicsville, MD
- Infraction
- Kraton 6s
- Typhon 3s
- Infraction 4x4
Corally offers CVDs to replace the dog bones in the rear. Is there a comparable situation with Arrma vehicles?
There's 2 widths first link is narrow with the fitment list at the bottom of the page. 2nd is wide with its fitment.You run the front cvds in the rear, but this will only work with the Kraton, Outcast, Notorious, Fireteam and Talion. It may or may not work with the Mojave but it will 100% not work with the Typhon or Senton. You also need to remove the rubber stoppers from the diff cups or else they will bind.
Yeah short and long sub axles that match the hubs. My cars are both short/narrowYes, the axle length is the same length regardless of narrow or wide hubs. The stub axle is what is longer for the Kraton hub.
I run CVDs on the rear of 2 of my Sentons. One has the normal rear hub (Hot Racing) and the other has Kraton rear hubs (Vitavon). The axle is the same as the front. The only difference is Kraton hub as the longer stub since the Kraton hubs are larger. The both attach the same way. The fit is snug which I prefer but I haven't had any binding issues and I haven't removed anything from inside the diff cups. If there's a difference in the length of the axle vs. the normal rear dogbone it's only 2 to 3mm max.You run the front cvds in the rear, but this will only work with the Kraton, Outcast, Notorious, Fireteam and Talion. It may or may not work with the Mojave but it will 100% not work with the Typhon or Senton. You also need to remove the rubber stoppers from the diff cups or else they will bind.
CVD with HR rear hub
CVD with Vitavon Kraton hub
