Big Rock Rear driveshaft broken
Jimmer101
Hi friends my drive rear has come off should I take the other wheel off or do I need to remove the motor etc to get to it ?
Thank you for your help appreciated !
Simon
Simon
I believe it should just pull out of the diff. Don't think there is a set screw? Didn't show one in the exploded view
If you hold the fitting you should be able to use a 2mm to unscrew the driveshaft Stub from the diff. when you put the new axle on you will need a long 2mm to screw it back in. MIP‘s are too short.
Yea I can get a 2mm in there but the whole driveshaft rotates when I turn screwdriver ? Nothing to get a grip on
Simon
Small pliers should do the trick. May need to release the arm to get in there. Unscrew the shock as well as the tierod.
Great advice it worked!
Good advice thank you
Great advice sorted !
Great thank you so much
