LOL .. A zero greased ring/pinion for 1What are we looking at here?
Then the steel insert for bearing obviously broken loose from the surrounding plastic housing ...
Thought maybe they were referring to the grind mark on the chassis under where the ring gear rides.For all I knew I was looking at the new gearbox. Hard to tell what we are supposed to be looking at without any sort of context.
What 3 or 4 used chassis I have seen post use have all had ring gear gougesThought maybe they were referring to the grind mark on the chassis under where the ring gear rides.
One of the corners is kind of craved in a very bad way which makes it weak when screwing
For all I knew I was looking at the new gearbox. Hard to tell what we are supposed to be lookinHi g at without any sort of context.
Then the steel insert is for bearing obviously broken loose from the surrounding plastic housing ...
Hi, I have replaced the housing and noticed that in one corner, the plastic is weak and craved which made the plastic so thin and yes i agree the bearing cover needs replacement or i will replace the bearing when the post arrives.LOL .. A zero greased ring/pinion for 1
Yeah thats one thing but is it something i should worry about? I was more concerened about the finishing of one of the corners inside the housing, when i inserted the screw it looked like it wont hold well due to the way it was badly cravedThought maybe they were referring to the grind mark on the chassis under where the ring gear rides.
Every single chassis I have has those too. It just goes to show the forces that these things go through.What 3 or 4 used chassis I have seen post use have all had ring gear gouges
