neighborhater383ci
Used a 3/4s receiver box to mount it up between the front body posts where it fits perfectly, just had to make standoffs and use longer screws to mount it with the same holes used for the mud guard. Did all of that in the name of lower cg and ability to run longer and/or more batteries. I moved the original battery tray as far forward as I could, sanded down the locating pins on the bottom + cut away a few areas to fit and then did the same thing to another stock tray but flipped 180 degrees to the original. Shown are two 3s 5000mah and they fit perfectly laying flat, but I’m going to be getting some large 4s packs for some 8s fun
