RCbuzz
- Granite
- Kraton 8S
- Kraton 6s
- Mojave EXB
- Senton 3s
I wanted to create a repository of free to use 3D designs that are in one organized place. I will do my best to update the thread as new designs are posted. One old thread was from 2020 so please be patient as I work through this and try to keep it maintained.
I want to tip my hat and credit @suchtragedy, @Camaroboy383, and all the other designers who have shared their work with the community! In my opinion this only adds another enjoyable aspect to an already fun hobby!
indicates model has been printed and tested by a forum member.
Arrma 1/10th Mega/3s/4s Lines:
WING / MOUNT:
Arrma 3s/4s TPU Wing Mount: https://www.thingiverse.com/thing:4503718 (@suchtragedy)
Remixed version of original design that @jondilly first made, published with his permission
Arrma 3s/4s Wing Mount Bracing: https://www.thingiverse.com/thing:4249767 (@suchtragedy)
This is a brace intended for the Arrma wing mount found on the Arrma Mega/BLX 3s Typhon, Outcast 4s, and Kraton 4s (Arrma Part #AR320455). The wing mount often breaks on the rear support strut where the wheelie bar for the 4s trucks usually mount. This brace is made to reinforce the mount to give it more strength .
Arrma Granite/BigRock/Typhon 3S Wing Spacer: https://www.thingiverse.com/thing:4723432 (DadsFriendlyRobotCompany)
SUSPENSION:
Arrma 6s Shock Bushing for 3s Vehicles: https://www.thingiverse.com/thing:4236723 (@suchtragedy)
Arrma 6s upper shock bushing which allows installation of 6s shocks onto 3s Arrma vehicles. This would be a functional alternative to Axial bushing commonly used for this, Axial Part #AXA1356.
Arrma Typhon 6S Shock Standoff for 3S (2023/03/09): https://www.thingiverse.com/thing:4420456 (jemery27)
Bushings for the top and spacers for the bottom part of the shocks. For using 6S shocks with 3S RC's.
Arrma 3S BLX Typhon Rear mud guards: https://www.thingiverse.com/thing:3386008 (bluemgt06)
Designed for Typhon 3S, "Since there was no way to mount with screws without drilling I used zip ties that go through the A-arm, seems to hold in place well."
Arrma 3S BLX/Mega Rear mud guards: https://www.thingiverse.com/thing:5364022 (Randomloser)
These are Arrma 3S(Granite/BigRock and so on) Rear mud guards. Used bluemgt06's mud guards as a template for the design.
Arrma Typhon 3s Front Suspension Arms (zero voids): https://www.thingiverse.com/thing:4214786 (@suchtragedy)
This is a 1:1 clone of the stock Typhon 3s front suspension arms with the only difference being it's a solid arm with no holes in it.
Arrma Spring Pre-load Spacers: https://www.thingiverse.com/thing:4611481 (TheFuzz1542)
5mm & 7mm thick stock shock spring spacers
Arrma 1/10 scale RC shock guards (2023/03/09): https://www.thingiverse.com/thing:1598573 (ThatRCGuy)
ESC/SWITCH MOUNTING:
Aftermarket ESC mount plates for Arrma 3/4s trucks: https://www.thingiverse.com/thing:4291910 (@suchtragedy)
This plate allows for easy install/removal of aftermarket ESCs when mounted in Arrma 3/4s trucks instead of pulling off your double sided tape and redoing it all the time.
BLX185/FIRMA 150 ESC Mount for Arrma 3s Vehicles: https://www.thingiverse.com/thing:4612362 (@suchtragedy)
This adapter plates allows you to shoehorn the larger BLX185 ESC into the Arrma 3s and 4s vehicles. This mount fits on top of the stock receiver box and includes a place to mount the power switch. PLEASE NOTE: This will not work with the Typhon 3s due to it's low profile body (ESCs cannot be mounted on top of the receiver box, there's no room).
PROTECTION/SUPPORT:
Arrma Granite Unbreakable Roof: https://www.thingiverse.com/thing:4808243 (caracalrc)
Full Roof Skid Protection
Arrma Granite Rear Roof Protection: https://www.thingiverse.com/thing:4805738 (Afterhender)
Roof Skid Rails
Arrma Granite Rear Bed Protection: https://www.thingiverse.com/thing:4805737 (Afterhender)
Full Truck Bed Rear Protection (Roll Overs)
Arrma 3S series bumper spring: https://www.thingiverse.com/thing:4835065 (choppaholic)
Remixed for TPU from: https://www.thingiverse.com/thing:4144767
ARRMA TYPHON 3S CENTER DRIVESHAFT BEARING SUPPORT (2023/03/09): https://www.thingiverse.com/thing:3867121 (@Camaroboy383)
Arrma 4x4 Driveshaft & Steering Crank Cover Set: https://www.thingiverse.com/thing:4654772 (@suchtragedy)
This cover set is designed to keep larger rocks/debris that fall in from the top and get caught in the center driveshaft or steering crank for Arrma 4x4 vehicles (Mega/3s/4s) with two options to pick from to accommodate both the short wheel base (SWB) and long wheel base (LWB) chassis.
ARRMA TYPHON/ BIG ROCK 3S CENTER SHAFT COVER 4S KRATON: https://www.thingiverse.com/thing:4000710 (@Camaroboy383)
Center drivehsaft cover for the arrma 3s and 4s line. This will only fit the LWB chassis.
3S Rear Brushless Motor Support for Arrma 4x4 3s BLX https://www.thingiverse.com/thing:4982263 (hyperion917)
Supports the rear of the 36mm brushless motor to prevent bending of the power module motor plate.
MISC:
SkyRC GSM-015 GPS Case+Mount for Typhon 3s: https://www.thingiverse.com/thing:4363541 (@suchtragedy)
This case fits the GSM-015 and designed to mount onto the unused front body post holes on the Typhon 3s.
ARRMA TYPHON 3S WHEEL HEX COVERS: https://www.thingiverse.com/thing:3867150 (@Camaroboy383)
Arrma 6s Lines:
COLLECTION:
ARRMA Kraton 6s EXB Collection: https://www.thingiverse.com/thing:4776557 (robschii)
WING / MOUNT:
ARRMA TYPHON 3S OR 6S THE WHOLE WING : https://www.thingiverse.com/thing:4152440 (camaroboy383)
ARRMA KRATON (EXB) 6S WING BRACKET: https://www.thingiverse.com/thing:4733549 (BYRIS)
ARRMA 1/8 Scale Wing Mount (Kraton/Notorious/Etc.): https://www.thingiverse.com/thing:4739985 (dcross)
Remixed design from: (BYRIS)
Arrma Kraton Wing Mount: https://www.thingiverse.com/thing:4781582 (ipnd)
Arrma Talion EXB Wing Mount: https://www.thingiverse.com/thing:5400580 (tobitobson)
Arrma Talion EXB Wing Mount (New Version): https://www.thingiverse.com/thing:5824393 (tobitobson)
Arrma Talion Low Profile Rear Wing Mount AR320379: https://www.thingiverse.com/thing:3414846 (tux3r)
SUSPENSION:
Arrma 6S shock cap protector: https://www.thingiverse.com/thing:4805517 (resu13)
Assuming design is for a V3, "I'm not 100% sure whether it fits the new V4/V5 as well." Rear longer version also included to prevent wing from pulling below tower.
Arrma 6S suspension Shims (2023/03/09): https://www.thingiverse.com/thing:4207690 (plangevin)
4MM dia are for suspension arms, 6mm dia are for pillow balls
Arrma 1/8 Scale Preload Spacer (2023/03/09): https://www.thingiverse.com/thing:2032661 (Jackhole)
Spektrum Firma 150 Replacement Power/Set Switches + Top Cover: https://www.thingiverse.com/thing:5877798 (@RCbuzz)
Intended to replace a broken or missing top half cover of the Firma 150 Power Switch.
Spektrum Firma ESC power switch mount for Arrma 6s off-road RC: https://www.thingiverse.com/thing:4579894 (@suchtragedy)
A Spektrum Firma esc power switch mount for the 6s Kraton/Notorious/Outcast/Mojave/Senton, securing the switch to the center roll cage. Shoutout to @Engineer who hit me up about creating a design for the Spektrum switch and for doing all the field testing of all the versions I made until it was good to release.
Hobbywing push-button power switch mount for Arrma 6s off-road vehicles: https://www.thingiverse.com/thing:4571093 (@suchtragedy)
This mount secures the power button to the side of the Arrma roll cage/center roof support used in the 6s Kraton/Notorious/Outcast/Mojave/Senton.
Hobbywing Max6 ESC mount for Arrma 6s off-road vehicles: https://www.thingiverse.com/thing:4571103 (@suchtragedy)
The mount/adapter plate allows you to shoehorn a Max6 into the offroad Arrma 6s vehicles using the 4 mounting screw holes on the bottom of the ESC, and then screwing the mount to the stock Arrma 6s esc mounting tray via predrilled holes in the tray. This is intended for people who want to install the Max6 without having to rely on double sided sticky tape to secure it.
Arrma Infraction/Felony/Limitless ESC Mounting Plate: https://www.thingiverse.com/thing:4495981 (@suchtragedy)
Screws into the 4 holes in the stock ESC mounting location so you can attach the plate with double sided tape your ESC of choice but making it also removable without having to rip the tape apart and replacing it again each time you remove the ESC
Hobbywing Push-Button Style Power Button Mount for the Arrma Infraction/Felony/Limitless: https://www.thingiverse.com/thing:4460584 (@suchtragedy)
Designed to screw on top of the Infraction/Limitless receiver box, makes it removable and no more sticky tape. Works with most Hobbywing 1/8 to 1/5 scale ESCs with the push button style power button and the various rebranded versions as well
PROTECTION/SUPPORT:
Kraton 6s Roof Sliders M3 and M4 Bolts: https://www.thingiverse.com/thing:4736706 (TCrain13)
Arrma Talion Arrma Talion EXB roof rails new version: https://www.thingiverse.com/thing:5824395 (tobitobson)
Bumper Spring for Arrma Kraton EXB Super Basher Front: https://www.thingiverse.com/thing:4783489 (Stewpid)
Arrma Kraton 6s mud guards v4 BLX (Laser Cutter): https://www.thingiverse.com/thing:4079939 (Dirtbag0_0)
Designed for use with a laser cutting machine (3mm Acrylic)
Arrma Kraton 2018 V3 Mud Guards: https://www.thingiverse.com/thing:2888273 (Slowprop)
Arrma Kraton 6s v5 Mud Guards: https://www.thingiverse.com/thing:4797165 (BallisticLotus)
Arrma Mud Guard Strong - Kraton, Notorious, Outcast, Talion: https://www.thingiverse.com/thing:4061770 (bisak)
ARRMA Typhon 6S Motor support: https://www.thingiverse.com/thing:5447988 (Stinhem)
ARRMA OUTCAST NOTORIOUS 6S TOWER TO TOWER BRACE: https://www.thingiverse.com/thing:3757640 (@Camaroboy383)
Offers the ability to hold the towers from forces in both directions.
Arrma Infraction 2-piece Side Skirts (small print bed friendly): https://www.thingiverse.com/thing:4398057 (@suchtragedy)
A 2-piece side skirt for the Infraction that is small print bed friendly
MISC:
SkyRC GSM-015 GPS Mount for Arrma Infraction: https://www.thingiverse.com/thing:4460557 (@suchtragedy)
Installs on either the front/rear body mount bar. Recommended install on the rear because the GPS will sit snuggly under the truck bed when the body is mounted preventing it from popping out in case of crash (unless you lose the body, that is)
Servo Spacer Arrma (2023/03/09): https://www.thingiverse.com/thing:5794256 (Printerman100)
Spacer for Servo (i.e. 1210sg Savox) on Arrma 6s cars. Adjust the height to fit your servo as the original servo spacers are not high enough.
Arrma 8s Lines:
WING / MOUNT:
Kraton 8s wing mount: https://www.thingiverse.com/thing:4717786 (snoprom800)
PROTECTION/SUPPORT:
Arrma 8s Front bumper shock: https://www.thingiverse.com/thing:5503993 (mdavid6) <-- Design Removed?..
Fan/Heatsink Stuff:
Customizable Fan Grill Cover: https://www.thingiverse.com/thing:2802474 (mightynozzle)
Incredible assortment of custom fan grills, sizes, and customization using OpenSCAD.
35mm Honeycomb Full Recessed 4mm Edges Fan Grill Cover (FIRMA150/BLX185): https://www.thingiverse.com/thing:5877793 (@RCbuzz)
Remixed from Mightynozzle's original design. Added size to fit the Firma 150 or BLX185 ESC, edges 4mm thick, pattern is recessed and 1mm thick.
Aftermarket Fan Adapters for RC Car ESCs: https://www.thingiverse.com/thing:4503682 (@suchtragedy)
These fan adapter plates allow you to replace stock ESC fans with a larger sized 30mm or 40mm fan with a higher rpm/cfm for better ESC cooling. The adapters are designed to sit on top of the ESCs without having to remove the ESC cover plate.
Adapter Options:
- 25mm to 30mm (fits BLX100/120/Max10, etc)
- 35mm to 30mm
- 35mm to 40mm
- 35mm to 40mm w/ embedded M3 nuts
Arrma Kraton 8s heatsink 30/40mm fan adapters: https://www.thingiverse.com/thing:4460604 (@suchtragedy)
Allows you to install 2x30mm or 2x40mm fans on the Arrma Kraton 8s Heatsink replacing the stock 50mm fan
Misc Stuff:
EC5 Connector Press (2023/03/11): https://www.thingiverse.com/thing:4703638/comments (apexNSW)
Used to press (or hammer) EC5 connector pins into housing.
Flysky FS-GT5 Radio Upgrades (thumb steering, menu knob rep, aux channel knob rep): https://www.thingiverse.com/thing:4647728 (@suchtragedy)
Improve the Flysky FS-GT5 radio to make it more user friendly, imo. Designs include thumb steering easy add-on, an easier to use menu knob, and Aux5/6 knobs that makes it easy to adjust with 1 finger (works great with Aux6 for rear wheel steer while driving.)
RC Wheel Balancer (uses Arrma 6s rear hub assembly): https://www.thingiverse.com/thing:4643011 (@suchtragedy)
RC wheel balancer that basically is a stand and to it you mount an Arrma 6s rear hub with axle/bearings/hexes. With the 6s rear hub you will be able to balance 17mm hex wheels but I've also included adapters that can be quickly mounted so you can balance 12mm hex and 14mm hex wheels.
50cal Ammo Box Lipo Organizer Tray: https://www.thingiverse.com/thing:4615986 (@suchtragedy)
Each set of (2) trays is designed to sit in the bottom of a standard military style 50cal ammo box. The total amount of slots for a pair of trays is (8)45x60mm which should fit most 3s-6s RC car sized lipos and (4)28x60mm which fits most 2s RC car sized lipos.
RC Body Clip Retainer/Tether: https://www.thingiverse.com/thing:4539691 (@suchtragedy)
Body clip retainer/tether to replace the stock arrma tether. There is another design on Thingiverse that is a closer replica to the stock Arrma tethers but I found it difficult to print because no matter the orientation it needed supports or the results were mixed and quality was meh. I made this as a comparable alternative and it requires zero supports.
Hobbymate Speed H6/HOTA H6 Pro Charger Stand: https://www.thingiverse.com/thing:4484740 (@suchtragedy)
Puts the charger on it's side at a 30% upward angle so you can see the screen from across the room.
WING / MOUNT:
SUSPENSION:
PROTECTION/SUPPORT:
Roof Skid Rails
MISC:
Arrma 6s Lines:
COLLECTION:
WING / MOUNT:
SUSPENSION:
PROTECTION/SUPPORT:
MISC:
Arrma 8s Lines:
WING / MOUNT:
PROTECTION/SUPPORT:
Fan/Heatsink Stuff:
Adapter Options:
- 35mm to 30mm
- 35mm to 40mm
Misc Stuff:
