vpr5793
- Mojave
Welcome to life, eh? HahaAh man!
First week I stepped into RC. After a full throttle the car has a grinding sound, released the acceleration, so far so good, and the car come to a stop with grinding sound. Picked up the car a gave a bit of throttle, still same sound. Then thought would think a lot of times, maybe this can be solved with force. Gave a few full throttles. long story short, burning smell from motor. Went home, opened the motor and bearing was almost complete gone. LHS said maybe I got a bad bearing, since this should not have happened within 4 battery runs. Got a new motor under warranty, but pretty stupid anyway. Strange sound from electronics, do not solve them by doing the same and with power. Second thing I did was buy thermal paste, heatsink, fans and hybrid ceramic bearings, cause driving a lot without them when it’s 35C (95F) doesn’t help either.
Other thing that probably a lot of noobs did was swear a lot at pinions coming lose only to figure out what the flat part on the motor shaft is for...?
I did that once many years ago. Can't recall the servo, but it wasn't a cheap one and it was brand new... I about threw up as I realized what I did. Except, I was drilling it out to tap it and use a proper 3mm screw... the drill got away from me a bit, but I thought I was ok... I was not.Removed my servo that I had already upgraded on my Senton to install the Kimbrough 124 saver. Did the trimming on the k124 and screwed it on the servo using the same screw from the arrma saver. Trouble is, the k124 has a deeper inset for the screw, making the screw way too long. Put it all back together, plugged in a battery and turned it on. The servo started wacking out, went full right, and proceeded to strip before I could get it turned off. Apparently the screw bottomed out and kept going, pushing against the circuit board. Just got my DS3225 servo that I'll be putting in today.
Burned myself on one of these - cause clearly that was the last time I ever did anything stupid with R.C.
We are spoiled today not having to deal with those POS and the mechanical speed control with its arm that always loses contact.Burned myself on one of these - cause clearly that was the last time I ever did anything stupid with R.C.
Might not be one of the stupidest things Ive done, but it wasnt exactly smart.
At least its good to see there was a good amount of grease in there.Might not be one of the stupidest things Ive done, but it wasnt exactly smart. Yesterday I was out bashing around my block and had a rickety jump I had made with a plastic storage bin, a cardboard box, and a piece of plywood. Despite being rigged it works great. Anyway I normally don't go for huge air because its on the street and I am running out of replacement parts. But last night I attracted a huge group of "Zombies" (Kids). Talbot calls them zombies. Anyway they were of course amazed at the jumps, backflips, etc. But they wanted higher, faster, cooler, etc. So I decided to go a bit faster this time on the jump and was amazed at how high it got off of such a simple jump. Anyway it went WAY higher than I expected and when it landed I immediately knew all was not OK. The rear shock tower split in half, the rear bumper broke in half, and I bent both rear tie rods. So that ended the night. Thankfully once again I had all the parts I needed to fix them, and straightened the tie rods. But like I said Im running out of extras so will probably take it easy for awhile. At least until I can start replenishing parts. Pics below. Moral of the story is don't show off for kids unless you are ready and able to fix some stuff. Because no matter what you make the truck do the kids will not stay impressed and will want MORE!!
View attachment 97111View attachment 97112View attachment 97113View attachment 97114View attachment 97115
