running and MMX8S with a 1717-1650 motor and I’m wondering what temps I should try to keep the esc under. Thanks.
Measures via IR gun or from data logs?Do not matter the motor or ESC the guide is this or within the range:
- 140-150 - ESC
- 170 - Motor (160 my target)
Ideal but always keep a temp gun close
I called CC and they said 220 for the esc. Somewhere I read internal ESC temps are 40 degree higher internally than measured
+1.For the ESC you want to shoot for 150 or less as Parcou mentioned above.
The MMX8s can heat up quickly so an aftermarket high cfm fan might be a good ideal
I don't like my motors to get much beyond 150F because internal temps and hot spots are likely much higher.
