Stampederfan
Ordered a V3 this morning and know I will need a servo and mount upgrade at some point.
Am thinking about picking up a Savox SW-1210SG servo as an upgrade but I have four questions:
I’m open to adding a BEC or a different server based on any suggestions you all may have.
Happy Holidays!
- It’s rated at 277 oz torque @ 6V - I see a lot of folks suggesting over 300 oz which this doesn’t have. I’m planning on running Backflips for summer and a slightly wider tire for winter (unselected a this point) and it will see a fair bit of snow so waterproof is important. I will be running a Dusty Motors shroud in the winter to keep the snow from packing up around the electronics. Does this servo have enough torque for my application?
- Do I need an external BEC with the stock BLX185 ESC? Seems like I should be fine to run without one since it’s 6V. If the stock ESC croaks in the future I’ll probably go Castle.
- Will this servo fit the standard size GKA servo mount or will I need the extended mount?
- I believe the stock servo arm will work with this servo correct?
Happy Holidays!
