Senton Senton 6s
Jason
Anyone know if I can put kraton or talion A arms and axil on a senton ?
Yes they will physically fit....however.... without changing other components not much will line up. The lower shock mounting points are moved out away from the centerline of the chassis with the longer arms, so you would need Talion shocks, steering arms, rear upper links, and rear hubs to make it all fit together. You may be able to use your stock rear hubs with minimal effect to geometry but I haven't test fitted these specific parts together to say for sure.
Ok thanks for the info, I think I'm going to give it a try
I did it but I didn't like it much afterwards so I changed it back.
