Senton Senton Overheating
GameFocusReview
  1. Senton 3s
As, the title says. My Senton 3s blx brushless is overheating. (I live in Florida)
I'm using a gen ace. 11.1v 5000mah 3s 60c lipo battery.
So is there any heatsink upgrade. Or do I put on a pinion gear to a 15T?
Any tips or trick I can do?
Thanks
GameFocusReview
  1. Senton 3s
Mine overheated because I had debris between the fan & heatsink, make sure this isn't also your problem
That might be it. Thank you.
Could also be something binding or the gear mesh being too tight. Is the ESC or motor overheating, or both?
Motor is always burning hot. then throttle stops working steering still work though. ESC is always cool.
Jon NC RC
Keep it fun......SEND IT
ArrmaForum Fan
NC Mtns
  1. Mojave
  2. Senton 3s
Thanks
when you turn the wheels, do they seem to roll freely, like when it was new? Going out on a limb here......
otherwise all stock, no modifications?
Silentknight
  1. Typhon 3s
Any chance its a bearing going out in the motor? That might be causing extra friction/heat. If you take the motor completely out, how does it feel? It should snap from magnet to magnet with no grit whatsoever.
Kla912000
Lawrence, Pennsylvania
  1. BigRock 4x4
  2. Typhon 3s
Everything is stock I just got it yesterday. The wheels are still roll freeling
The wheels are still roll freeling?
First of all, where are you running it? If you run it thru grass it will heat up. Grass causes a lot of resistance to the small 1/10 rigs, especially the Senton which is low to the ground.
GameFocusReview
  1. Senton 3s
I been running it on dirt. sometime grass but mostly dirt.
I just got this Rc truck I would think everything is good. but I will check it.
GRC
Solutions
1
With a motor fan, the motor still overheats before the ESC does. If you're running hard without any breaks you will overheat in Florida weather. But how hot? Do you have a temp gun? You should have one. Depending on how hot, it could be a sign of a bad motor bearing.
GameFocusReview
  1. Senton 3s
Soon I will have a temp gun still shipping. Motor always overheat first then the esc does. If it is a bad motor bearing can you fix it or you have to buy a new motor?
RC-Dude
Use a smaller pinion gear. I went down to 17T on 3s. Think the 20T is only good for moderate or colder weather. We race on pavement and with 20T the constant acceleration and braking is too much heat.
Jackjax801
Pickle Rick!
SLC, UT
  1. Vorteks
The V1 and V2 trucks only have four pinion sizes you can use due to pre-drilled motor mount holes. Those could be modified to accept different pinions. The V3 trucks can accommodate various pinion sizes due to the motor mount having slots that you can slide it in.
GameFocusReview
  1. Senton 3s
If it is the bearing, you can contact Horizon Hobby with your proof of purchase and they should send a new motor. After that, you can buy new bearings for your original motor to fix so you have a spare. There is a lot of good information in this thread regarding fixing the motor https://www.arrmaforum.com/threads/blx-motor.20999/
I took the motor apart and the bearing just was destroyed. So I contacted them and still waiting for a response to them. Thanks.
