Outcast Servo travel
thepiper
Winnipeg, Manitoba
  1. Notorious
I'm confused on how to adjust endpoints on the servo. I put the radio into the mode, got a fast blinking blue light, and it slowed down once I let the throttle back to neutral. I then turned the truck on and tried adjusting it. I was left with no servo response, and even trying to go through the steps again doesn't do anything. I see that rebinding is necessary as per the manual, but how can I adjust travel if I have to rebind with the slightest change?
SrC
RC is a lifestyle choice
Solutions
1
Queens, NYC
  1. Infraction
  2. Limitless
  3. Kraton 6s
  4. Mojave
  5. Notorious
  6. Outcast 6s
You have it backwards.
Are you using AVC or is it disabled?
Which Radio model and Rx are you using? There are 2 stock RTR Radio Types. You did not say which. 🤷‍♂️
I think you are not getting into the End Point Settings mode properly.:(
If you have the DX3 radio, the following manual helped out another member a few weeks ago.
This is the Thread linked below.
https://www.arrmaforum.com/threads/kraton-8-steering-end-points.36701/#post-502965
thepiper
Winnipeg, Manitoba
  1. Notorious
I got it working. Something just went wacky. Bound it up again, using the non-avc mode, and steering worked, and was able to trim again.
