Shock Oil
Discussion in 'Raider' started by MNRaider, Aug 25, 2017.
  1. MNRaider
    MNRaider Active Member
    Aug 14, 2017
    Arrma RC's:
    Raider
    What shock oil are you all running in your raider? Brand and weight?
  2. Rdub
    Rdub Well-Known Member
    Apr 20, 2016
    458
    306
    Long Island, NY
    Arrma RC's:
    Raider
    I've been using Team Associated 40wt and have been pretty happy.
    Davidmbailey likes this.
  3. Kristian83
    Kristian83 Active Member
    Sep 18, 2017
    9
    Arrma RC's:
    Raider
    are you experiencing any certain issues with the standard shocks?? i have experimented with some budget options to improve the standard setup. Or if you are looking for an upgrade i can possibly help you there too.
  4. MNRaider
    Aug 14, 2017
    Arrma RC's:
    Raider
    I just got the STRC metal upgrades (my caps keep popping off the top of the shocks) just wondering what weight oil I should use when I rebuild them
  5. Kristian83
    Sep 18, 2017
    9
    Arrma RC's:
    Raider
    Depends on what type of driving you normally do?
    I found the standard shocks extremely lazy and pretty much useless so i modified mine by adding 2 extra holes of an equal size in the pistons to get the fluid to travel faster and that alone has made the biggest improvement so far without having to upgrade to full aluminum suspension. If you are wanting to ever upgrade then go with Traxxas 3760 and 3762 shocks in a few aftermarket brands.
    try using a 40 or 45W oil and see how you go. i have played with oils before the shock piston mods with 60 and 50W. After i made the modifications to the pistons i am trying 35W oil and i will go from there. Plus with modified pistons i tried to get the tops to explode and they haven`t yet. Even try adding one extra hole to the piston to start but i knew what i needed to do straight away and went for the 4 hole piston mod.
  6. Pooch692000
    Pooch692000 Active Member
    Oct 26, 2017
    17
    Arrma RC's:
    Raider
    I bought trackstar shocks and fillled with 30 and 40 weight (forgot which wt jn which schoks off to of head) and a few other mods- wheelie bar, rear and front hex nut adapters from strc, front and rear hinge pins from strc and front tower from strc. Also have proline badlands for rear tires. My new raider blx is coming for xmas and wanted to run stock for a bit before i do the upgrades. Any idea what stock shock oils weights come in shocks? Planning on switching over to the trackstars with the front springs from the stock raider and rears that came with trackstar shocks
  7. Alexander ¯\_(ツ)_/¯
    Alexander ¯\_(ツ)_/¯ Well-Known Member
    Dec 24, 2017
    16
    4
    Arrma RC's:
    Raider
    I just use standard motor oil, as your shocks will tend to pop every once in a while. It works the same as any expensive "RC Shock Oil". No point in spending money on a 8oz. bottle of RC oil when you can just use the stuff you put in your car. I think I even used vegetable oil once...
  8. Davidmbailey
    Davidmbailey Well-Known Member
    May 23, 2018
    3
    NW Louisiana
    Arrma RC's:
    Raider
    +1 for the TA 40 Wt.
  9. arrmaracing
    arrmaracing Well-Known Member
    Jan 11, 2018
    269
    70
    Sydney
    Arrma RC's:
    Fury, Kraton, Outcast, Senton, Talion, Typhon
    Veggie oil classic lol
  • Welcome to Arrma Forum
  • Disclaimer
