Shock rod ends?
Thread starter #5
Slyslinger
Likes
1
Kraton
Yes indeed..just ordered some
Thread starter #7
Slyslinger
Likes
1
Kraton
Yup that's where I seen you post about the nero ends a little while ago. Where can j get the tekno setup
Thread starter #9
Slyslinger
Likes
1
Kraton
Sweet I'll grab them next time one breaks..just next day aired a set from tower hob
Mr.Duke
Likes
500
NC
Outcast
Yo I have them in and installed but the top little nut that holds them is stripped where can I find that tiny thing
I'm not quite sure which piece you're referring to. Can you post a pic and I'll try and point you in the right direction?
chevys10zr2003
ArrmaForum Fan
Likes
502
Minnesota, USA
Kraton, Senton, Typhon
https://1drv.ms/u/s!As7bwf4BMVY4gSsTirKPBKMnUEpb not to sure how to upload a photo yet I'll just message arrma customer service
Here are the nuts for the tops of the shocks. A local hardware store might have the 2.5mm nylon lock nut so you could check there first to save time and money. You can find the part numbers for everything on your vehicle in the manual that came with the vehicle as well as from https://www.arrma-rc.com.
https://www.towerhobbies.com/cgi-bin/wti0001p?&I=LXDZBV&P=ML
Thread starter #15
Slyslinger
Likes
1
Kraton
Thanks a lot! What about the part the nut screws onto with the hex head on the other end are we able to purchase that?
chevys10zr2003
ArrmaForum Fan
Likes
502
Minnesota, USA
Negative. that's the part that just came in. I'm talking about the shock mount with the allen head that the lock nut screws onto you slide the shock onto it hard to explain kind of.. I'll have pics tomorrow.. they might be both stripped
Are you talking about one of these three parts?
Thread starter #20
Slyslinger
Likes
1
Kraton
These are the nuts I need part # AR715001 and the part that these nuts bolt onto
Similar threads
