Willl
Does anyone make a Front and Rear Skid Plate for a Typhon S6 V5?
Unfortunately I haven’t seen any specific to the new V5 chassis redesign.. the best solution I could see would be to use these two part numbers and to trim to fit?Does anyone make a Front and Rear Skid Plate for a Typhon S6 V5?
Based on Arrma website the kraton exb front bumper will be compatible. Granted I'm still not sure how. And I'll double check but I think a rear wheelie bumper is available according to that websiteDoes anyone make a Front and Rear Skid Plate for a Typhon S6 V5?
For sure would still need one in my opinion...With the two new v5 "sliders" on the rear, is the rear skid plate still needed? i'm going to try running mine naked when i'll switch to the V5 chassis.
I just bought these for my V5 Typhon 6S (according to the Arrma optional parts section, they do fit):Does anyone make a Front and Rear Skid Plate for a Typhon S6 V5?
Yes. i've fitted that bumper onto a Typhon. You need some hardware. the 2 bolts that hold it form the bottom need to be 2mm longer than what you currently have, and you need some 4m bolts for the front part.But for the bumper, it's less clear how that fits. Doesn't come with any hardware at all and I'm not sure if stock bolts will work... Will have to sit down with my car and work it through... If anyone else has any experience with fitting this to a V5 Typhon 6S, I'd be grateful for some tips!
Thanks mate, good advice and good idea to look at the Kraton EXB exploded viewYes. i've fitted that bumper onto a Typhon. You need some hardware. the 2 bolts that hold it form the bottom need to be 2mm longer than what you currently have, and you need some 4m bolts for the front part.
Take a look at the Kraton EXB exploded view to see what you need.
As mentioned the Super Basher Front Bumper does fit the Typhon S6 V5 but does not come with hardware https://www.arrma-rc.com/part/ARA320573
You will need 7 additional screws (outlined in blue) which I sourced from my collection of screws I picked up from Jennys RC https://jennysrc.com/collections/notorious-v6-blx-ara8606v5
I was able to reuse the 2 screws that attach to the chassis (outlined in red)
The RPM Rear Skid Plate #81442 does not fit the Typhon S6 V5
An earlier post suggested to try to trim the skid plate but the material in the location that needs to be trimmed is too thin
I'm still on the hunt for a rear skid plate/rear bumper
Can you add a pic with the body on so I can see how the exb bumper looks on the typhon. Also do you like it?Good idea, I replaced the two 12mm screws with two 16mm screws, perfect fit
Nice! Looks extremely well-protected. I ordered the Jenny's RC hardware set for the Typhon V5, but that's going to take a while to arrive (shipping US to Australia).I've only have the Super Basher Front Bumper on for 2 runs
Day 1 was street only and I did not hit anything but it did help between the street and driveway aprons
Day 2 was off road, hit a metal pole at low speed and the car bounced off the pole, no damage, other than that it helped me plow over as opposed to into some mole hills
I'm guessing it clears the tires no problem? I definitely like the look and it has held up on my kraton exb still to date.I've only have the Super Basher Front Bumper on for 2 runs
