kartracer93
My outcast is slipping gears and have rebuilt diffs with thicker oil and shimmed them between the bulk head and diff on the front and back diffs and it’s still slipping not sure what it could be other than the pinion inside the bulk heads are to loose or damaged However they looked to be fine not sure I need to I need to shim inside the diffs inside the gearing on the gear side of the diffs it seems no matter what I do it just keeps slipping
