jondilly1974
Speed running apprentice, motor Slayer 🤘
- Toledo, OH
- Granite
- Infraction
- Kraton 6s
- Kraton EXB
- Senton 3s
- Typhon 6s
- Typhon 3s
My Typhon 3s does 50mph completely stock so I would assume that the Typhon 6s V3 would have to do more than 50mph, otherwise what is the difference between 3s and 6s?? With a typhon 6s you should be getting about 70-80mph
There are other factors at play too. The 6S stock has a lower pinion at 14T vs 3S 15T. It also has a lower kv motor (2400kv vs 3200kv). You need the extra battery voltage just to make up for the added weight, pinion, and motor out of the box. After putting in the 20T pinion it should hit 70mph on 6S.
