- Felony
- Kraton EXB
- Senton 3s
So, as some know I'm building my first speed rig from a mega infraction.. on my setup I had to throw some limiters in the shocks I upgraded too, 10mm in the front and 8mm in the back.. my question is how much travel is too little!!?
I know some run turnbuckles instead of shocks and others run really stiff setups.. so let's just say I threw some 6s shocks on it and went the stiff rt.. do you guys think a 1/4 of travel on the front is ok if I have a stiff preload setup.. given it's a 3s platform and weighs like 6lbs I doubt much compression will take place.. I wanted to keep the rake as true as possible but I can swap the fronts to 8mm if need be!? I'm still fresh to the speed scene so forgive my lack of knowledge on the matter!!
