Granite Speed run tires
Joe-Swanson
What are y’all using for y’all’s speed run belted tires? Going on granite 4x4 with 3300kv motor with 32p 57 spur and 21t pinion!
Grps are the best rubber tire.....need 17mm thou to fit..
And which of the grps do you recommend
I'd go with softer ones since granite is so light.ive got XM3 on my mini-typhon that's on a granite chassis..just make sure to get the newer xm ones like this,older ones aren't near as good
I just put together the new HR spool with 34t spur gear for the 1/10...looks to be a nice product. Haven't tested yet thou...
I've got a swb an lwb 1/10 both setup for speed..they are very fun an fast,at less than half the cost of 1/8,1/7 to run,an when ya crash them much less to rebuild....check out my YT videos,got alot of 1/10th speed videos on there..ran 73mph on 2s with granite chassis typhon today..mini-typhon
Gotcha buddy what is your
Gotcha buddy what is your YT account
And does anyone know of any other bodies that fit the granite
