Darren W
I had bad experiences with foams and wont run them on a 1/8 or 1/7 car again.... unless I had access to a large airstrip ?
...... Does a long straight on a race track count?........
I’ll do my best not to put it in to those but you can guarantee that it will head for that small area rather than the 3/4 mile clear area.Yes as long as you don't put the car into those tires you stand by....
Me tooGlad you kept it on the road. ??
More than I can say ??? Mine has ditch magnetism lately. ?Me too
Quick reflexes and a whoooooole lotta luck on that save ?
You’re supposed to say it was all skill and you weren’t even concentrating at the time....Me too
Baby steps with speed increase but it’s going in the right direction.
This was on my last set of new Hoons and it was planted. The next run will be on foams.
That's inspiring; my goal for the end of this season is 135! Good stuff man ?Baby steps with speed increase but it’s going in the right direction.
Now you gotta update your signature from 125mph...
Congrats on the new PB
Thanks. I have set myself a target for the end of the year but if it takes longer to get there then so be it. Good luck with your goal!That's inspiring; my goal for the end of this season is 135! Good stuff man ?
I made two passes over the weekend with the Limitless on foams for the first time. I was using Sweep racing medium foams, and was nervous about running them but it went pretty well.. I had much better traction than I thought I would and had no crashes. Also got a best run of 125mph with plenty left in it, and most importantly the car felt pretty planted under acceleration which is what I was really wanting to see.. I would have done another run but traffic was getting heavy where I was so I called it a day. I’ll get out again next weekend and push for a bit more
Thanks! The yellow lettering is a sticker that comes with the tires. I did notice a difference, I had much better traction with the sweep foams than with the BSR double pink I tried before. When I ran on the BSR’s I had to roll off the throttle because it would fishtail around under acceleration, but these Sweep foams hooked up and were pretty planted. I still wasn’t going all out but I could get the power down. This Toyota GT body makes downforce also so I’m sure that helped as well. I used the medium compound and they held up well after the run, no chunking or any issues. Now that I see I can run on foams reliably it’s a relief to not have to worry about blowouts! I’ll still use the hoons and GRP for anything under 100 mph but serious runs will be on these..Nice!
I love the yellow lettering on the wheel/tire. Do you feel the traction is different between the BSR and Sweep?
Probably not apples to apples comparison unless you test both with the Delta Plastiks body, but that is good feedback to know regardless.Thanks! The yellow lettering is a sticker that comes with the tires. I did notice a difference, I had much better traction with the sweep foams than with the BSR double pink I tried before. When I ran on the BSR’s I had to roll off the throttle because it would fishtail around under acceleration, but these Sweep foams hooked up and were pretty planted. I still wasn’t going all out but I could get the power down. This Toyota GT body makes downforce also so I’m sure that helped as well. I used the medium compound and they held up well after the run, no chunking or any issues. Now that I see I can run on foams reliably it’s a relief to not have to worry about blowouts! I’ll still use the hoons and GRP for anything under 100 mph but serious runs will be on these..
Man I wish I had a motor and a calm day. It’s been either windy or something every time I’ve tried to run the last two months. I need to feel that sense of accomplishment again. Happy for you ??Rewarded for my efforts this morning with 3 clean, straight passes that got progressively faster
View attachment 101945View attachment 101946View attachment 101947View attachment 101948
Tempted to make a 4th pass but seeing how my goal for the day was breaking my previous best mph of 123 and I did that 3 times over, I’ve decided to pack it up and head back to the farm while I’ve still got a big grin on my face ?
