Speedrun Custom Wheels // 250+ MPH
When your going at them speeds wtf does it look like inside that bullet, must be just a flash of light .and how do you get all that pressure out of your cab? I would imagine at them speeds your face would be pushed back into your head ...holy fuk dude .you one brave .tough bastard 👍
It’s a rush hard to explain but close one eye in your car as you drive thru a tunnel
That's going to be Very difficult to make happen..
Because as soon as the "loose" inner ring gets shifted due to any vibrations or jolts from bumps in the road ,it will cause your wheel to have a death wobble ,once it starts..
That even with ultra stiff shocks won't be able to get them back under control >> at those High speeds (160+ MPH)
Maybe if you had a beadlock ring that sealed the outside face and trapped the centrifugal locking ring inside?
Kind of like a centrifugal clutch, that forces a stickier material thru the holes.
We are rebuilding it for this year speed week in Utah new motor
Just just under 3500 hp the small motor
I'm pretty sure he means tire. That's what the pros use. This is the rear wheel assembly of the Thrust SSC, top speed 763 mph (more than 1,200 km/h).
This is the wheel of the Bloodhound SSC (they're taking aim at breaking the 1000mph barrier).
Top notch brother. 👌
The thing is that that is a non-wheel powered wheel. Our R/C car tires are spinning 3X the RPMs as the fastest wheel driven car.
That is not the Castle we know of sadly, I looked it up. They make airplane parts and more.
Yes I know all about speed running with rc car and full size land speed vehicles
I know. That, however, wasn't the point of my post. I was merely pointing out that aluminum tires are a thing.
