I place the Mugen shims assembled just as with the OE setup. One shim behind each Gear.
The Armma Option Metal diff cannot fit the tombstones. And are not needed with it.
One Mugen shim kit will do all 3 diffs. Using all the Mugen shims.
Tossing all the stocker shims.
This setup might feel a bit snug at first. But should rotate no issue. There will be an initial breakin period, as with all diffs. And will maintain smooth diff action for way longer after a breakin period.
Always Clean all the parts well before assembling. EVEN if the parts are brand new! Shims, gears and all.
Brake Spray solvent is best to clean diff parts.
I find that a metal diff is needed mostly at the center. It tends to runs hot, depending on your setup and how you drive. I've melted a few Center plastic diffs. Never a Fr or Rr one.
Metal diffs add roational weight and mass, so I don't run them at the front and rear. Just the plastic OE ones with the Tombstones.
But... I always use the Mugen shim kit with all my diffs.
Edited.
