After the combo upgrade i did get a 17t pinion gear to replace the 15t. Everything is already in and seems to be running fine, but i want to slowly upgrade parts knowing the stock stuff wont hold for too long.Remember to buy a 0.8 mod 5mm shaft pinion gear (stock is 15t, i run 18t) because the 48dp mega pinion wont work with the 0.8mod 57t spur.
Hey when you upgraded the slipper clutch, how does the drive shaft connect to the new end of the clutch? Did you also have to buy ar310881 and Ara311030Thanks. Yeah its a complete different truck after the combo. It really forces me to be careful haha. Yup its 48dp. That pinion should work with the ARA311034? It was from the list of optional parts on the arma site.
I do want to run 3s eventually as well.
