Topdeck07
Hello everyone,
Hate to introduce myself this way, but I am having a very frustrating issue. My son wanted to get into RC cars, and well I thought it would be pretty fun to go back into the hobby after many many years. So, today I went down to the LHS and bought 2 Mojave 6s' , Spektrum dual charger etc. I got both of them unboxed and bound after charging the batteries (single 6s) and took them outside.
My son's car ran for about 5-6 minutes and then just became unresponsive. I turned both the vehicle and the Tx off and restarted. The ESC no longer makes any startup noises. However, if I turn the truck on before I turn the Tx on, it will make the noises. When the Tx is then turned on, the fan goes down to a very slow rate and there is no response to any inputs on the Tx. No lights blink on the ESC.
To clear up future questions here is a list of considerations:
Any ideas?
Thank you in advance!
- The truck will make startup noises (chimes?) only when started with the Tx off
- When the Tx is turned on, the truck "dies", i.e. fan on ESC slows way down and truck is not responsive
- When the truck dies, no lights blink or are solid on the ESC. The only light on is the receiver
- Light on the receiver turns on and off when the Tx is turned on or off (it sees the Tx)
- I swapped the battery for the battery in my truck and still doesn't work
- I swapped my son's battery into my truck and the truck turned on and functioned as normal, i.e. battery seems fine
- I tried rebinding the Tx and that didn't work
- I tried resetting the ESC to stock and that didn't work
- The Tx had brand new batteries in it, swapped them for another brand new set, nothing
- Vehicle was driven with the throttle limiter at 50%, tried starting with other configs, nothing
- Throttle trim is at zero
- Dry conditions, driven on short grass and pavement. There is no lose grass or anything binding the fan and everything is bone dry
Any ideas?
