It's more of that damn loctite. I just keep heating it until I see smoke from the loctite. If possible I use a pinion puller which doesn't help you unless you have one.Thanks, I managed to get off the grub screw with a tork. But now I can't get the pinion off. I've tried pliers, a hammer and heating it to the point of melting...
Cover the aluminum with a rag and use a flathead screwdriver under the gears. Heat it up first, then "pop" down on the end of the screwdriver.Thanks, I managed to get off the grub screw with a tork. But now I can't get the pinion off. I've tried pliers, a hammer and heating it to the point of melting...
I have those exact drivers...they are nice.
Here's my work of art from yesterday ? This was in my Granite. I cut the gear so I could get the motor plate off. I then used my pinion puller to get it to where it is now. I can't for the life of me get it the rest of the way off. I got so pissed off I threw the whole thing in the garbage only to fish it out a few hours later (I have 3 other BLX185 motors). This all started with a stripped grub screw.
I'm trying to save the pinion. Do you think that would ruin it? ?There is a lip on the end of the shaft preventing the gear from coming off. You could slice along the length of the gear on both sides with a dremel being careful not to hit the shaft. Then split the gear with a screwdriver.
