Spook
- Points
- 138
- Granite
Hi All,
Having just changed the slipper assembly in my v2 Granite to the V3 set-up, I needed the change the input gear for the shorter shaft..
Had a bit of a nightmare with that bit and the bearings, even used new bearings but seems a pushed one down a bit far and needed to pull it back up…. This proved to be a real nightmare…
I have previously bought a bearing puller for my toolkit but that didn’t help as it wasn’t big enough to go around the shaft of the input gear…
Can anyone recommend a suitable bearing puller that will work on this please?
I suspect I have damaged the bearings now trying to get them sorted so suspect I will be doing it again soon and really want a decent puller to help!
Many thanks
Many thanks
