Don't think I ever heard of an 'S' rating but, even if, it's meaningless.
You definitely want the $ rating i.e. bang for your buck
Good choices are abo
Yeah im a noob. Maybe I worded it wrong..."s" rating 2s,3s,4s,6s,8s you know wtf I meant. And if you don't then you're more ignorant about it than me. If you've got nothing constructive to add then just scroll on by. ThanksDon't think I ever heard of an 'S' rating but, even if, it's meaningless.
Good choices are above.
In the future I'm positive I'll have more. But for now I have my talion 6s which I think I need a better radio. And my 11yo daughter has granite 3s. Her radio seems to work great. So I guess for now it would be the formerWhat are your plans for R.C.? Are you going to have a few cars where you have one radio for each car or are you planning on having a good number and would like one radio to control all of them? If it's the latter, you're looking at a computerized radio that has multi-model capabilities (binding to several receivers).
Thank you for your input. I'm still new to this and trying to figure it outNo harm done, I never heard of an 'S' rating with respect to transmitter/receiver. That had me thrown for a loop.
Now that you elaborated a bit that is only for the type of battery for your rig and has nothing to do with picking a transmitter/receiver.
When I got the V1 Mojave and the V4 Kraton they both came with STX2's. I knew that before the purchase and knew of the complaints. So when I tried it for the first time on my 6s Kraton, I drove it for barely 10 minutes, packed it up and went home. I have better multi model radios here anyway and needed to see for myself how bad the STX 2 was. Dam crap was garbage, worse than I thought considering the bad reviews. In that 10 minutes, I even changed out new AA's for another set of AA's . I couldn't believe how bad it was. Signal drop's, driver input latency. Felt so disconnected from driver input. Range was crap. I think I got the worst of them all. When I got my V1 Mojave, that STX 2 was tossed to the side from the get go. Reciever and all.So I just got a talion (v4 as I have kindly been corrected) and have as well determined the stx2 is garbage. I did not notice until really opening the car up in a park where the delay at high speeds became noticeable. And have lost comms a couple times at range that shouldn't have been an issue. Also heeded SrC's danger warning, have the DumboRc-X6 arriving tomorrow. Not fancy but is supposed to have excellent range and quick response, and has gyro capability. I'll let you know how it goes, was also considering the Radiolink RC4GS but it was out of stock until 3/8 yesterday when I looked. Just looked at the link and they magically have one now...
Arrma has the oversized Rx box available now for larger RX's. ( 6s rigs) I think first seen on the EXB 6s Kraton. It's an option part now.Check the classified, there is a DX3 system for $60 , problem is that the receiver will be an extreme tight fit and probably not work without a minor mod.
The Dumbo or RC4GS are good but suggest looking at some youtube videos. People have issues setting them up regardless.
Honestly, any radio is better than what came with the Talion, sad to say.
RC6GS Radiolink . Have it. Recommend it. There is much discussion elswehere on this radio. As cheap as it is ($80.), the range of the Version 2 with included 2 wire antenna Rx has longest range. Everyone will split hairs on this. Short of modifying a Futaba radio, This is the best. I use it on my Lim. It beats out my other more expensive radios including my Noble NB4. A nice radio that can be used with a 4k mah Lipo 2s battery instead of AA's if you want.I was thinking about a radiolink RC4GS V2. How's the range really on these? Is it good enough for a speed run. I have DumboRC transmitters, but I'm tired of the number of transmitters I have around. I have Flysky Gt3B, but it's maxed out and for my early Traxxas cars. Looking for someone who has one to give me their opinion.
