Note: This feature currently requires accessing the site using the built-in Safari browser.
A lot of people use the 6s Typhon shocks as an upgradeHello Arrma forum I’m wanting to know what is the best shocks or upgrades in general for the typhon 3s.
Awesome I noticed that was an option but at little pricey.A lot of people use the 6s Typhon shocks as an upgrade
Thanks these should suffice, but what would be the most less likely to leak?"Best" is rather subjective, but shocks that are much better than the stockers can be found in this forum thread. Lots and lots to pick from!
You check Jenny's rc?Awesome I noticed that was an option but at little pricey.
Oh I see they’re $50 for 2 so not that bad considering they will probably never break being that the buggy is only 8lbs.You check Jenny's rc?
So far I haven't had any issues with mine ..Had them installed for about 2months without any issues.Ok how are the hot racing metal shock body upgrade, would those not leak?
No bends, no leaks, bashing hard no 15ft jumps around but if its in my way i'm airborne. I bash all my rc's even on road; so if i can't break it im not bashing it hard enough...Ok good to know any bend shafts? How hard are you bashing them?
Ok good to know, you see 20-30ft jumps what a want to do with it but have it its first test run and the shocks bent off of a 15ft jump, so do you think that those will still hold up?No bends, no leaks, bashing hard no 15ft jumps around but if its in my way i'm airborne. I bash all my rc's even on road; so if i can't break it im not bashing it hard enough...
Idk to be honest.. I'm not sure but if your trying to go that big you might want to go with the 6s shocks..Ok good to know, you see 20-30ft jumps what a want to do with it but have it its first test run and the shocks bent off of a 15ft jump, so do you think that those will still hold up?
I have a 6s talion I’d do that with but I’m trying to see if the small 3s typhon is worth it to be cheaper or not.Idk to be honest.. I'm not sure but if your trying to go that big you might want to go with the 6s shocks..
