Ordered a flir camera for android. Going to compare spare motor with a stock set up on identical batteries. (15t)not a bad idea, I did wonder if it would be any use doing this given the heatsink is a bit of a sloppy fit. I've got the same motor in my stock granite and it gets too hot to touch after a decent rip.
I've found some thermal paste and done it myself and will report back once new body posts arrive and I can get the thing back out.
I used arctic silver. What did you use?ok so after running 2 packs through it back to back, ripping ovals in my yard then up and down my street at top speed I can report that the paste has made a decent difference. It would use to get too hot to even keep a finger on but now at LVC that was not the case, still hot but not crazy like it was.
poor fitting heat sinks that trap a layer of insulating air between the can and sink and impede conductive heat transfer.
